Grafham Traveller / Catamaran Open [George Stephen]
Archive
Archive
Post by Archive »
George Stephen wrote:
Thanks Grafham , and Bob, for running this successful event. 33 Dart 15s with lots of visitors made for good competitive sailing, especially from some of the newcomers to Travellers' Events.
I was really impressed by Robin Boardman from Halifax? who finished 5th overall - a really good achievement for a relative newcomer (he's had his D15 for a year and a bit, and this was his first "Open" as far as I know) so watch out for him and 1515 at other events.
So if you sail at a club with small numbers of D15s have been tempted to try a Travellers' event, I think you'll find something to enjoy, whether it be a good performance like Robin's or taking advantage of the opportunity to pick up tips from the "pros" and sail better. If you think you're going to pick up tips, you can usually recognize D15ers from their green or navy sweatshirts. Don't hang back from introducing yourself, and asking for some tips and hints.
1594
Queen Mary SC
Archive
Archive
Grafham open and travellers [Robin Boardman]
Post by Archive »
Robin Boardman replied:
Thanks George for your generous comments. I feel I must point out that whilst this was my first Dart 15 open, it is far from being my first sailing event.
Nonetheless, I was very pleased to have done as well as I did and have to say I thoroughly enjoyed myself.
The fleet were very welcoming and I found their enthusiasm for what they were doing infectious. I was pleasantly surprised by the standard of racing and learnt more about the boat with every race - and I realise that I still have a lot to learn about sailing the boat in more wind.
So as George says, open meetings like this are well worth the time and effort involved. The racing is excellent and there's always something more to learn. I will be attending more opens for sure - I recommend them whole heartedly.
Whilst I have your ears, I noticed that some of the Dart 18 sailors had skeg protectors on (supplied by Fluid Boat Services). They seemed like a good idea to me and I wondered why no Dart 15s had them on. Any comments anyone?
Robin Boardman
1515
Halifax SC
Archive
Archive
Skeg Protectors [George Stephen]
Post by Archive »
George Stephen replied:
Skeg Protectors are a good idea, especially if your skegs have previously suffered and been repaired only using gelcoat - this latter is really too fragile, as I know.
But there's not much point in using them on soft surfaces - grass, sand, when there is little chance of damage. Arguably the beach at Grafham is not soft, but with care damage can still be avoided.
I have some standard Laser Centre Skeg Protectors, which live in my "cocktail cabinets" when not on the skegs. Had my skegs not already been in need of some repair I might have used the protectors to try to keep the skegs in pristine condition when at Grafham.
I don't think much of the standard Laser centre skeg protectors - they are quite fragile. Maybe the Fluid Boat Services ones are made of better material (eg alumiinium alloy on the outside which will hit the ground, rather than whatever plastic is used by Laser Centre.
But note that some D15ers were using hull supports under the sterns when on the beach.
Archive
Archive
Skeg protectors [Keith]
Post by Archive »
Keith replied:
I had a quote from Steve sawford for protectors which are, I believe cheaper than the D18 one see below:
Yes, we do have the skeg protectors you describe. These would cost ?20 inclusive of VAT, plus ?2.50 postage and packing.
If you do wish to place an order for these, either e-mail us back, or you may prefer to phone Steve direct on 01536 330477.
Your cheque for ?22.50 would need to be made out to 'SSM Ltd' and sent to:
Steve Sawford
15 Dryden's Close
Titchmarsh
Kettering
Northants
NN14 3DD
Archive
Archive
Skeg Protectors [Simon Liston]
Post by Archive »
Simon Liston replied:
The launch area where I am and the beach where I often sail to and park up for a cup of tea are not exactly soft white powdery sand so skeg protectors sound like a very good idea.
Having all the practical skills that make Frank Spencer look like Handy Andy I'd like to ask if they are easy to fix on.
Thanks,
Simon.
ps. My cat is called 'Skeg' and he'll probably be interested in a set aswell!
Archive
Archive
Skeg protectors [Robin Boardman]
Post by Archive »
I have only ever seen the skeg protectors I described made by Fluid Boat Services. I am not sure what type George and Keith are describing but they would certainly look out of place in a cocktail cabinet - and indeed on Simon's cat!!
These were similar to the hull pads seen on many cats which are placed under the transom of each hull and held there by elastic over the top of the hull - except in this case the elastic is attached to the middle foot loop.
At ?70 they are dear compared to SSM's model but I fear they are a rather different beast.
Thank you all for your replies - I need to do some more investigating.
Archive
Archive
Skeg Protectors - James Bond [Simon Liston]
Post by Archive »
I know I'm showing my ignorance here but are the protectors fitted to the hulls and in place while you're sailing or are they something you 'slip on' just before dragging the Dart out of the water?
I guess unless they were fixed on really flush to the skegs there'd be all sorts of drag problems.
What we really need of course is a set of retractable wheels so we can sail up the beach just like the amphibious Lotus Esprit (I think) in that James Bond film ;-)
Simon.
Archive
Archive
Post by Archive »
are for protecting the skegs when ashore, not for use when sailing! When used they stop damage to the skegs when you stop wheeling the cat along on its trolley, and let the stern down to the ground. The skegs hit the dirt first, unless you have the trolley a long way back when the stern end under the transom can and will hit first - clearly NOT protected by skeg protectors. If you want to be really careful you'll use hull supports - usually seen only on cats with "centre-boards" in each hull.
When you launch and have the cat in the water you take the skeg protectors off - if you forget, then the standard Laser Centre ones will be pulled off by "drag" andflip about on the shockcord - of course you had slipped the free end loops round the toe-loops, hadn't you - don't ask me what you' attach them to if you've removed (or never had) your toeloops. OPutting them on in the shallows as you come ashore is clearly best, but not always easy - you may have to get ashore as carefully for the skegs as you can and then put on the protectors.
The Laser Centre ones are just Vee-profile plastic, with an angled closed end for the rear, with a foam material insert.
OK!
Archive
Archive
skeg protectors [Keith]
Post by Archive »
Keith replied:
Hi, I think the SSM skeg protectors are "V" shaped with elastic. The Fluid systems ones are also good and no doubt protective, but bigger. I have two specially moulded plastic boxes about 25cm high which do the job, but I find them awkward to use, they are particularly awkward when getting the boat on and off the road trailer, which was why I was thinking of changing them to the "V" sort. Merely being carefull does not seem to work for me!
Archive
Archive
Skeg Protectors [Geoff Howlett]
Post by Archive »
Geoff Howlett replied:
I should like to add that the new Barcelona hulls seem to be constructed in a different manner to the older boats, in that the glass is not brought right out to the skegs. The sheets are folded along the general line of the hull and the skeg is constructed of filler and gel. This gives a very water tight hull but the skegs are very fragile, as we found out at Marconi.
Archive
Archive
Skeg protectors [Simon Rowell]
Post by Archive »
Simon Rowell replied:
I have used the Fluid Boat Services skeggies for a year. They do the job well especially on the pebbly beach at Felixstowe Ferry. My boat only has the rear toe loops so I have to fix them to the toe straps using an elasticated 'pranger' (the things you use for securing luggage onto roofracks for example). One end is fixed to the elastic on the skeg protector by squeezing the hook shut with a pair of pliers and then taping over it with electrical tape, the other just goes over the toe strap. These skeggies are made of fiberglass with a foam lining and seem indestructible but they are about ?70.
