Mast Pre-Bend
Hewett
Mast Pre-Bend
Post by Hewett »
New member advice needed...
When looking up my mast from the base, i can see a little fore / aft 'pre-bend' (i.e. bending slightly backwards towards the top). There is no lateral (sideways) bend visible..
Is this normal or result of a defective mast ? I've seen this on other cats, but only those withe diamond stays..If it is a defect, i guess it will have the effect of making the sail flatter than normal..
Chris
Re: Mast Pre-Bend
Hi Chris,
The mast should be straight when unloaded and without the sail up. Once you hoist the sail it becomes curved aftwards caused by the tension on the downhaul. Then as soon as you hook on the mainsheet the bend increases due to the load on the clew caused by the mainsheet, This is most pronounced when beating. When running you should release an inch or two of the downhaul to increase the fullness of the sail.
Hewett
Re: Mast Pre-Bend
Post by Hewett »
Thanks for your comments Bob. I noticed it when de-rigging after sailing, suggesting the mast is bent....going to check it again !
