Mast Floats
Posted: Sat Feb 11, 2012 6:58 pm
by Mike Godwin
A question came up at our Safety Boat Workshop last night regarding whether the Catamarans at our Club should have Mast Floats fitted as part of the membership, I have read through some of the older threads previously posted on line, but most refer to how to right from invert, but I think the discussion is wider than that. We have 6+ Dart 18, a couple of Hobbie 16 and 2 Dart 15. Got to say, having been able to right from Inversion on more than one occasion ( famous last words) I do not fully understand the discussion. What do other D15 sailors think ? are there Floats available for the Dart 15 and 18's on the market, really do not want to put an empty plastic Coke bottle on the mast unless I get sponsorship from CocaCola for the advertisment ! seems unlikely. Appreciated.
Re: Mast Floats
Posted: Sat Feb 11, 2012 7:53 pm
by Andy B
On a D15 I can't see the need for a mast float, I'm well accustomed to capsizing
myself :D and have never had a problem righting from inverted. Sometimes I've actually
found it of benefit for the cat to totally invert as it lessens the chance of you getting
detached from it as when on its side the trampoline catches the wind and can move
down wind quickly in a blow.
Andy
Re: Mast Floats
Posted: Sat Feb 11, 2012 8:25 pm
by KarlPountney
Mike,
Andy is quite right, there's no real need for a mast head float on the 15. I've put one on our Club's Sprint 15 when youngsters have taken the boat out but found a mast float does tend to foul the halyard. You don't need it.
It's interesting that you bring this up following a Safety Boat Meeting at your club. Quite frankly, as a Powerboat/Safety Boat instructor, the most straightforward approach to dealing with the situation with capsized catamarans is training and a small amount of practice. The fact that most Cats slowly invert is quite helpful in a rescue situation as the boat tends to stay put while you recover the helm/casualty from the water. The RYA Safety Boat Handbook shows pictorially (and in words) the method and it takes about 2-3 minutes prep and 2 minutes max to right the boat. Importantly, you need to ensure that all support boats have long tow lines to make a strop tied on each of the beams.
All of the (reasonably priced) Safety Boat courses we run at Stewpot and the refresher training provided to Safety Boat Captains includes righting Cats (usually the club boat) and we've seldom had a problem during normal racing or recreational sailing sessions - just a few mud-stuck-masts and that's all. Other than 15s we've Stealths and Prindles and they all right quite happily with the correct technique and it's no more complicated that conventional boats with a centreboard still in the case/broken.
I hope this helps.
K.
Re: Mast Floats
Posted: Sat Feb 11, 2012 11:35 pm
by Andrew Hannah
I'd be very surprised if the powerboat instructors, in question, have ever sailed a catamaran. The question to ask them is, "How would you right an inverted Sprint"? The blank look on their faces should prove their ignorance.
Re: Mast Floats
Posted: Sun Feb 12, 2012 9:31 am
by Mike Godwin
Guys, great comments, to be fair, we do not have ANY Catamaran Instructors and you are correct, the Powerboat instructors and crew in most cases do not have clue. Last year I volunteered to capsize and invert my Dart 15 for others to practice and learn, but we did not have a huge turnout, but it was good practice all the same.I am concerned that the Club thinks a Mast Float is the answer, when we should be concentrating on the safety boat training aspect first. I will be taking the subject back up with the Commitee with my concerns.
Re: Mast Floats
Posted: Sun Feb 12, 2012 11:54 am
by George Love
At Carsington, an RYA Training centre, we run a good number of courses to learn to sail cats. It is a condition that all trainee boats use mast flotation when under instruction and we have purchased special devices for the purpose. As a multihull instructor, it certainly gives me some peace of mind that, if it all goes a bit pear shaped with novices, entrapment is much less likely to be a problem.
HOWEVER, I do not know or have never seen any experienced helms using them for recreational sailing and certainly not in a racing mode - just creates more drag and poor windflow which defeats the object.
Despite the fact that we are a big cat club, I know there are many safety boat crews who haven't much of a clue when it comes to dealing with a capsized or inverted cat. I, therefore, teach my pupils to take the initiative by taking charge of the situation and instructing the attending safety boat on what to do and also to assess their own safety. E.G. on one occasion I did not race on a Sunday - big wind with a gybe mark close to leeward dam. I took the view that, should I dump it here, I was not confident that the safety cover could prevent me from being blown on to the dam before I'd righted it!
In conclusion - when training (and especially with youngsters) use mast flotation (I think it's an RYA recommendation). Other times it's the sailors call. As others have said, the important thing is to have competent safety crews who are comfortable around capsized cats and mast flotation is not used as a 'get-out'.
Just my thoughts
Re: Mast Floats
Posted: Mon Feb 13, 2012 8:48 am
by Jaycb
Hi all,
I ought to fess up that it was me who raised this subject in the first place.
Here's my thoughts.
The first thing to remember is that our Dart 15s go fully turtle VERY quickly. Unless you do an almost dry capsize and are ready with the rope the boat will be right over before you've got everything prepared.
Even though we try to ensure thorough safety boat training re. cats (Mike himself helped organise a session last year) there will often be safety crews that just don't know what to do - it's just inevitable. It's hard enough to get crews to dress appropriately for duties, never mind being prepared to get in and help. As George mentioned, he prefers to take charge and instruct the crews what to do (or not do). This may be fine for skilled single-handers in calm conditions, but at a coastal venue with potentially damaging breaking waves conditions will sometimes not be ideal.
I've read Bob's excellent article about righting a Dart on this website, and even Bob himself uses phrases like "this may take some time..." when describing the steps to go through. That's the point - sometimes you won't have that luxury of time. A mast float buys you time. Just imagine you're 100m from breaking waves in an onshore blow and the boat goes turtle - you're going to be wrecked before that boat is back upright. You might still need a tow out by the safety boat but at least the mast won't dig in and snap if you have a mast float.
A mast float also allows a safety boat to right the cat single-handed - I've seen this done many times on holidays, even without the active participation of the cat sailor.
Remember too, that all the while a safety boat is "standing by", they're away from the action and may miss another incident. If a float helps the boat to be righted in half the time then that's a good thing.
Finally, consider the danger of entrapment. If a cat goes over and someone's wrapped around the mast with their own trapeze then having a mast float buys them more time to free themselves.
I can see this has potentially opened up a whole can of worms and to be honest I don't think we'll ever be able to force people to use mast floats, but nor do I think they should be dismissed as mere training aids.
Re: Mast Floats
Posted: Mon Feb 13, 2012 2:25 pm
by George Love
As I said in conclusion, outside of training, I believe it's the sailors call to determine whether or not they use it. :D
Re: Mast Floats
Posted: Tue Feb 14, 2012 10:12 pm
by Charles
Hi Mike / Jason
If NSSC think about recommending or requiring mast head floats for cats I can see no argument for not doing the same for monos, especially open transom boats.
Also they should take legal advice from the RYA, as the question from the owners would be "what type of float" & then what position would the club be in if this float failed, would they be liable as they had made it a requirement?
It has always been a tenant of UK sailing that the skipper has responsibility for his ship's & crews' safety & should make the decision as to whether it is safe to sail or not, or whether to reef or not, or whether to use a float or not.
After all, your club did not recommend a boat for you to buy because of it's safety record.
Of course all these issues are very grey areas so if you want to use one do & if you don't then don't.
Educate don't legislate!
Re: Mast Floats
Posted: Wed Feb 15, 2012 10:16 pm
by paulgrattage
Mast head floats would make certainly the dart 15 and 18 out of class. You may get away with it on the 15 but they would certainly have to be removed on the dart 18s to race at a dart 18 event (you aren't even allowed a righting line on a dart 18). You also run the risk if the float broke off holes from where it was would cause the mast to fill and then you would never right it.
