Page 1 of 2
Mainsheet & shoulder pain
Posted: Thu May 27, 2010 9:50 pm
by Charles
I don't know about anyone else, but after being out in a good blow I find my shoulders really aching & my chiropractic bill seems to be increasing year on year (& yes, I'm a RELATIVE youngster!!).
What do people think about allowing an increased purchase on the mainsheet system?
Before I go any further you need to know that I've got the old style plain blocks which are shackled together rather than the more usual torpedo shaped ball bearing block system.
I've been experimenting & have changed the single blocks for doubles, which seem to work well.
Each RWO double block costs around £37 (in northern money!) so I could argue this comes in under the nominal £50 limit for an amendment to section 10 of the class rules.
I also do not believe there is a performance advantage. Overall weight is slightly higher, there is more sheet to haul & more possibility of oversheeting.
What do you think? Is it worth a proposal at the AGM? Could I propose it as a requestable allowance on medical grounds??
I look forward to your views.
Posted: Fri May 28, 2010 7:07 pm
I would have thought that more mainsheet could be seen as a disadvantage so that shouldn't go against you. Just as much work to do. I think your shoulder pain must be the penalty of being such a good heavy wind sailor, Charles. If you don't get this through you'll just have to slow down a bit. Come to think of it maybe I should argue that this modification would be an unfair advantage
If you don't have any luck you might just have to follow the example of some of the old fogies and just leave the thing cleated all the time. If you must have it really tight, pull it in with
two hands (that'll slow you down a bit, maybe)
Posted: Fri May 28, 2010 8:26 pm
by Gordon
If I could turn this topic around the other way, so to speak.
Any one know the class legal position on using less purchases on the mainsheet block in light winds if you wanted to? By that I mean not using all the available rollers.
To me, more purchases equals more leverage but less feel, which can be useful in the right conditions.
I remember from my Laser sailing days (way back) holding the mainsheet direct from the boom for better control.
Regards...Gordon
Posted: Fri May 28, 2010 10:00 pm
by Charles
From my laser days I thought that holding the mainsheet fall from the boom was against class rules, but I might be wrong.
In terms of reducing purchase I think we should assume it is not allowed unless stated as allowed, that way we remain 1 design. So it's a possible proposal for the AGM.
Whatever happened to the mainsheet & trapeze cleat proposals from 2008, they are not incorporated in the rules currently on the website.
I note that lasers now use 6mm mainsheets, perhaps we could do away with diameter restrictions, as per our jibsheets & allow helm preference.
Posted: Sat May 29, 2010 9:31 am
by Robin Newbold
Charles - Don't pull it in so much, I've heard it's just as fast that way
Posted: Sat May 29, 2010 12:30 pm
Yeah, try letting it out quite a lot. I'm sure it's considerably quicker, the more you let it out...
On the grounds of health and safety (we don't want Charles to get injured) and inclusiveness (not so able people should not be excluded because they can't pull the mainsheet in) and because there's no written rule to say that you can't pull the mainsheet in with less pulleys (so why not more) then perhaps Charles' suggestion should get a hearing.
Also I'm sure that Bob Carter once told me that the old sheeting system has less purchase than the current one, so here is an example of differential purchase already built in to our class.
Mainsheet and Shoulder Pain
Posted: Sat May 29, 2010 6:15 pm
by George Stephen
I think most of you know that, despite an operation and subsequent steroid injection, I have a muscle inside my right shoulder that remains weak - prone to partial tearing or worse. From time to time this injury recurs to a significant extent, sometimes from sailing in stronger wind and more likely when "Sporting". It then needs rest and medication to recover enough to be able to sail, quite possibly for some weeks.
But if you might think that I would be in support of Charles's suggestions, you're wrong!!!!
My boat has the current variety of mainsheet blocks. Increasing purchase by adding extra blocks would not, in my opinion, be possible. To add extra purchase I would have to purchase, at considerable expense if purchased new, a set of blocks that could be capable of allowing adaptation at further "little expense" to create that extra purchase (or already have that extra purchase "built-in"). So Charles's suggestion is only possible at little expense on that subset of the one-design boats we sail that has the original style of blocks.
I also wonder whether an extra long mainsheet might not also have to be purchased?
I oppose strongly any resolution that could favour only some of the boats in our one-design class at little expense, while the rest would have quite possibly considerable expense to make use of any potential advantage.
I think Charles should undertake some physical exercises to strengthen and improve the stamina of his shoulder muscles.
Re: Mainsheet & shoulder pain
Posted: Sun May 30, 2010 5:31 pm
Charles wrote:I don't know about anyone else, but after being out in a good blow I find my shoulders really aching & my chiropractic bill seems to be increasing year on year (& yes, I'm a RELATIVE youngster!!).
And I thought that you were the iron man on our circuit
Posted: Sun May 30, 2010 5:36 pm
Robert wrote:Yeah, try letting it out quite a lot. I'm sure it's considerably quicker, the more you let it out...
Robert, miss quoted I'm afraid. Both systems have 7:1 purchase. It is just that you had 2 blocks missing on yours. I seem to remember helping you out to get you back in class
Posted: Mon May 31, 2010 11:29 am
by Robin Newbold
I might be misunderstanding/missed the point here, but if you add blocks to your current mainsheet, you wouldn't be able to sheet in as far?? So to solve this you'd need 4 wheels top and bottom (similar to an F18??), which would be quite a bit more expensive.
Posted: Mon May 31, 2010 3:58 pm
Bob Carter wrote:Robert wrote:Yeah, try letting it out quite a lot. I'm sure it's considerably quicker, the more you let it out...
Ah... blown on that one - guilty as charged! Wound George up a bit, though.
What about a steam capstan like they had in the old Fifies?
http://www.nmm.ac.uk/visit/exhibitions/ ... in/reaper/
Posted: Thu Jun 03, 2010 12:19 am
by Charles
Robin,
I think you're too used to scanning text quickly in order to get out to the pub asap! I'm talking about changing single blocks for doubles & possibly doubles for tripples; but I have the old, separate block system so it's possible for me without lengthening the overall arrangement.
George,
Thanks for the fitness advice. The reason my left shoulder doesn't fall apart completely is that I have strong muscles from many years of competitive swimming & waterpolo, which hold my shoulders together, but ache when doing so as the joint is often slightly displaced.
Your point about having the "new" style blocks & not being able to add to these is of course, quite correct. I believe this was a manufacturer's upgrade, which I am sure had it been proposed at an AGM would have been vociferously opposed by someone, such as your good self. As it is you have enjoyed the benefit of these blocks while I have continued to labour with my plane blocks which so love to capsize & jam. I could upgrade, but that would cost me £126.04 + postage, a little more than the nominal target of £50 we set ourselves...
However, if we consider upgrading the mainsheet system to an alternative system of, say, 2 tripple & 2 double Harken Carbo blocks the total cost would be (looking quickly at a random website) £147.98 + postage, a differential with the "bullet" blocks of a mere £21.94, seems worth it for an increase in purchase ratio from 7:1 to 11:1
Yes, a longer mainsheet is necessary, but I do not believe this is an issue under the current rules.
You use the phrase "...make use of any potential advantage." It is important to keep in mind that this is not a speed advantage & indeed could be a positive disadvantage when handling the additional sheet length, the ease of oversheeting & additional weight of more blocks and sheet.
I look forward to your response.
Posted: Thu Jun 03, 2010 11:02 am
by Robin Newbold
Ahh right I see now. going from 7:1 to 11:1 should make it easier to sheet in, but I find I get knotted up in the ropes there already.
Posted: Thu Jun 03, 2010 8:26 pm
I think that Charles has a good point. Would the association favour individual exceptions to strict rules where a health issue is clearly interfering with a person's ability to compete?
Mainsheet Blocks et al
Posted: Fri Jun 04, 2010 12:15 am
by George Stephen
Robert,
Did you really intend to give prospective Sprinters the notion that we are such a bunch of geriatrics that we need special modifications for our various disabilities?
Allowing specific concessionary variations for sailors with injury or "wear and tear" problems would be a nightmare for the Association Committee members. Who decides when an injury is sufficiently severe to allow a variation? And what variation should be allowed? Our Committee does enough for us without loading them up with what you suggest. If we have variations they surely have to be allowed across the board to all members.
Charles,
Sorry to read that your aching shoulders are due to an underlying physical problem. Given my shoulder problem, I sympathise; I grimace and bear it; sometimes I have had to control the mainsheet primarily with my good left arm and shoulder, regardless of what tack I'm on; and sometimes I have a right old moan; but I don't expect any special allowance to be made for me.
Do your old-style blocks jam due to wear and tear over their years of use? If so, then it's about time they were replaced.....
Note that the current style of blocks aren't perfect - the sheeting runs close, so a delay in sheeting in as you luff from a run to a beat can result in the sheeting jamming as a loop of sheet gets caught up.
The old-style and current blocks both offer the same 7:1 sheeting ratio, ie the same degree of control of the mainsail. If the old-style blocks work ok without jamming when new, then I can see NO reason why I would have objected to the new blocks when they were introduced by "force majeure".
I wrote "any potential advantage" with some care, because I could see the disadvantages you list. But there's no denying that a potential advantage accrues because an 11:1 system offers finer control of the overall mainsheet system tension, and hence of the shape of and power developed by the mainsail, and hence in boatspeed.
But I return to the point that you concede - you can make the change for around £37, but it would cost me £110 more than you at £147. (Based on the figures you quote). Not nominal.
