Starting in mixed fleets
Posted: Thu Oct 15, 2009 6:50 am
by RobBowen
There may or may not be a discussion to be had here!
At Netley most of our racing is handicap in mixed fleets as we've not got enough cats racing regularly for our own start. A couple of times recently (purely by chance!) I've found myself getting a blinder of a start, perfect postion, pin end of the line etc, but then as all the monohulls point higher than me have found myself with pretty much nowhere to go, having to slow down and duck behind them, because as windward boat I need to keep clear of them.
It could be my misunderstanding of the rules, or not! Any advice would be great...
Rob
Posted: Thu Oct 15, 2009 9:52 am
No it is a right pain sailing in mixed fleets. With just skegs and no centreboard we make a lot of leeway which means that you just cannot start with other boats close to leeward. You have to plan for it and not necessarily get the best start position but go for having some space to leeward and go for speed to make some space. The other thing is the way that the PY system works on average performance. In light winds we tend to end up at the back of the results
but then again in a good wind we tear away and it is hard for monohulls to compete
There is no remedy unless you build a fleet of cats and get your own start. Even if you don't get your own start you can guage your performance against the other cats.
I recommend that you cheer yourself up from time to time by coming to our traveller series - class racing is the best way to improve and you meet many like minded sailors.
Posted: Thu Oct 15, 2009 4:28 pm
by Kyle Stoneham
Bob has got it pretty much bang on there, only other advice i could give is go through the line at full speed with a run up... accelerating from standstill on the line as many monohulls prefer to do is not fast for a sprint.
You will soon have room below to bear away and remain in clear air. The option to tack off early is always there too!!!
Posted: Thu Oct 15, 2009 4:41 pm
by Neil Parkhurst
If you have the perfect start you should be way in front of the monohulls so shouldn't be able to luff up. If not they have to give give room to keep clear so fair warning therefore as Kyle says to tack if needs be.
Posted: Thu Oct 15, 2009 6:28 pm
by RobBowen
Thanks chaps, very useful - especially about trying to hit the line at full speed. Most of the monohulls are pretty quick RS5,6,700s, so we rarely get the option of getting away from them unless it's proper windy! I've only really noticed the issue since Carsington when it was a real luxury starting with other boats going in the same direction as me!
Posted: Thu Oct 15, 2009 6:55 pm
by capella
I have suffered the same pleasures at gurnard for a couple of years now,when punching the tide tacking of isn't an option and starting nearer the shore means you tack back out into the path of starbourd tackers,stating on the pin at speed is usually made hard by mono's parking on it and avoiding the higher pointing boats squeezing you out but sometimes it does happen,when im kept up by a mono right underneath me i just pinch up with it untill its clear ahead and i can bear off behind it,sail through its dirty wind then get going.Agree with bob about the wind strenghts,the more the better,wind and tide together suits me so the spinnaker boats cant use them for so long.
Martin.
Posted: Fri Oct 16, 2009 2:55 pm
by Charles
Rob
We also have this problem at Halifax SC.
For a number of years we raised the issue of safety, but the mono's weren't interested... they were looking forward at the line & not aware of the sharp pointy bits coming towards them at 10 knots & all the evading action we had to take.
I have always advocated a separate start, even if cats & monos sail in the same handicap race.
Eventually, the committee agreed to try letting the cats go on the 4 minute gun. Unsurprisingly, the monos still got in the way as they jostled for position with a minute to go, they did look around a bit more though & realise this wasn't the best solution.
Now the monos start on 4 minutes & cats on 5.
This is a little better.
It was nice last Sunday for me to get to the first mark about 500yds ahead of the monos, it was a F7 !
Even with 4 spectacular capcises I did 2 manic laps to their 1 !!
Fair Winds
