Putting the hulls together for the first time. [Martin]
Posted: Thu Jun 06, 2002 4:17 am
by Archive
Martin wrote:
Will be putting the boat together for the first time on Sunday, but am not really sure how the hulls fit together. (Think I will be OK with the rig) Have now gleened from earlier threads that the trampoline holds everything together and it should be tight. However, would be grateful for any tips. In particular what does the shockcord do in the forward beam and how do the spring clips work in the back beam? What is the best way of getting the tension in the tramp tight enough? Being based at Wells in Norfolk, I will go and have a look at the Darts (15,16 and 18s at Blakeney Point SC to see how they are rigged. Sadly I was not aware of a blue rigging folder when I bought the boat and the previous owner never mentioned it. I will probably not be able to access e mail or this site after tonight as we will be travelling tommorow so any tips today would be much appreciated.
Many thanks.
Hulls [Tim Benton.]
Posted: Thu Jun 06, 2002 6:18 am
by Archive
Tim Benton. replied:
Lay the first hull on its side, with the inner side facing up. Drop the forward beam into the hull, then the rear beam by pushing the spring hard to one side and allowing the clip to clear the edge of the beam.
Lay the hull over and move the other hull onto the beams, trying to keep the movement as equall as possible to avoid the hull jamming.
Feed in the tramp and tighten with the rope provided, tighten again usings a piece of wood (2x1 ish), and hey presto, a Dart 15. No tools, no drama.
Your tramp will probably need tightening again after you have used it a couple of times.
Rig tension seems to be a moot point and I am not sure what is the best tension. I have mine so the mast is slack enough to rotate through 90 degrees, but ask about and see what suits you best.
Happy sailing.
Hulls [Keith]
Posted: Thu Jun 06, 2002 12:15 pm
by Archive
Keith replied:
Brian Phipps cataraman book has a photo, step-bystep guide to putting a dart 18 together (which is very similar to a D15). It shows assembly from bits Its also in print and has a good photo guide on how to handle the unlikely event of a capsize!
