Comments on this site are not necessarily the opinion of the Dart 15 committee.
Comments are not moderated and people's screen names may not be accurate.
I am glad (?) to see that I am not the only newcomer to be struggling with tacking (Simon)!!
I have read The Catamaran Book, which is excellent. Yet I still struggle to tack.
I take to the water and spend 2 hours just trying to complete a successful tack and still end up at snails pace or worse having to paddle my way round!!
I have tried fast, slow, sheeted right in and right out and still no joy.
Is there some magic trick that can be performed to enable a successful tack?
Gybing is a piece of cake, if a little scary in a good blow. So why cant I tack?
There must be a guru out there who can give this poor, paddling man a tip or two.
Firstly, don't worry, we've all been there and once you get the knack its quite easy. I'm by no means an expert, but here's my thoughts:
The main problem is of course that you have to swing the boat through about 90 degress with no power available from the sail. So the only way to succeed is with the boat already travelling forward, and to minimise any braking effects whilst doing the tack - these include the wind, waves, boat trim and of course the two brakes hanging off the back of your boat! That's easy to say, whats it mean in practice?
1. Sailing Unarig (main sail only)
Light winds: to initiate the tack, push the tiller extension smoothly (and quite slowly in v.light winds) so that the rudders are at about 45 degrees. Don't move your body weight around the boat much until the bows have passed through the wind (in very light winds I try not to move at all until well through the wind). Rapid movement of rudders/boat trim will just help slow the boat and risk stalling.
Moderate winds: this is probably the easiest; smooth use of the tiller and move across the boat just as the bows go through the wind.
Strong winds: this is where I've always had more problems. You need to get good boat speed before starting the tack, and try to pick a flat bit of water; a big wave can easily stop you mid tack. You do have a get-out-of-jail card in stronger winds; do a 3 point turn if you get stuck. All you need to do is reverse the tiller and wait for the wind to blow you backwards - the boat will then swing round through the tack and you can then sheet in and off you go.
2. Sailing with jib.
Basically as per Unarig, but it can be easier in strong winds as leaving the jib alone so that it becomes backed as you go through the wind will help push the boat round. I'm sure some of the sprinters will offer some more tips here as I'm not an expert.
In all cases above, you should keep the main sheet tension on until the boat goes through the wind, then release it a bit so the sail curvature can pop over to the other side as you sheet in again.
So to summarise:
- get good boat speed before the tack
- smooth use of the rudders (should not need more than 45 degs)
- don't move your body weight over until the bows have gone through the wind
- avoid big waves
Hell: pressed the wrong buttons
Rule 1: You must be moving, close hauled.
Rule 2: Remain sheeted in.
Rule 3: Steer gently through the wind, and follow the tiller, moving your weeight to the middle.
Rule 4. Bear away if necessary on the new tack, and a slap on the new windward side of the main helps.
Then you cane sheet out a little, get moving, then point up and sheet in again.
Takes about 3 seconds normally.
Enjoy the Teach in.
Is 3 seconds going full speed into tack and getting up to full speed on new tack realistic? Reckon I would be struggling to do that in my National 12, let alone my Dart 15. Will keep practicing!!
