Folks,
I'm getting reports of people who are using Windows 7 but cannot login to the chat pages.
I have tried it from my work Windows 7 box and can login and post without problems using IE8, since this has a heavily customized setup its hard to tell whether something in the setup has resolved the problem. It maybe some firewall issue or IE setting that needs to be adjusted.
I'll try and build a standard Win7 PC with no customized settings to see if I can replicate the problem.
Thus if you post using Win7 and have solved the login problem could you post here what settings you need to set so that others in the same boat can get back up and running.
Thanks,
Martin S.
