Trailer board & mast support
I've just acquired one of the metal trailer board & mast supports which fits on the pintle & gudgeon of each hull, as shown on Windsoprt website. There are no bolts with the support to attach through the gudgeons. Do I just use any old 2" bolt & nut, which will fit, or is there something else designed to do the job?
Hi Charles,
I bought bolts and nuts from my local ironmonger, at 15pence each. Not stainless bolts from a yacht chandler which are much more expensive. I'd also suggest "wing nuts", as they are easier to turn.
Lighting board
Hi Charles
I've used this type of lighting board for years, and secure it with screws and locking nuts. The board will bounce up and down on the pintles unless you screw the nuts down tight.
Kevin :)
Nyloc nuts
I would be concerned about wing nuts unless a spring washer is used - and that could 'eat' into the casting.
I use bolts and nyloc nuts with flat washers but the bolts are only partially threaded (i.e. have a smooth section that sits inside the casting - so that any movement will not cause the thread to grind the inside of the casting.
I've just bought a trailer board, to atach to the gudgeons the owner used padlocks with long shackles (the U-shaped bit) with tape wrapped round to pad out the shaft.
As the fit is snug it seems quite a good idea, secure & quick to release.
