Greasey Balls
Greasey Balls
Hmmmmmmm.........
That sould get us some extra hits !!!!!!! Hold on to your hat Martin!
To grease, or not to grease that is the question, whether it is nobler to suffer the slings & arrows of abrasion or to get nasty sticky stuff all over your new chino shorts...
I don't grease, I can't see the point... appologies for continuing the inuendos.
I've had a boat with a mucky ball (ordinary car grease used) & I've tried teflon grease, but while that's beter, it still attracts muck (northern term for dirt).
So is there any rationale for greasing?
Marks will be awarded for higher inuendo count & inappropriate use of the bard than the above.
Andrew Hannah
Post by Andrew Hannah »
I grease the towing ball on the car, but don't bother with the ball on the boat.
Last edited by Andrew Hannah on Thu Jul 29, 2010 7:15 pm, edited 2 times in total.
Fading star of the Thorpe Bay fleet
Former rugby player in the extra-B
Struggling musician
Second best cabbage in the village show...
Jaycb
Post by Jaycb »
Charles,
I suggest a small amount of grease. Keep a small plastic bag & a strong rubber band handy, then slip over your greasy ball as soon as you un-hitch - prevents ruined chinos and flies/fluff/grit etc from collecting until you're ready to tow again. Simples :)
"Pray for the wind"
I definitely don't grease the car towball because it would contaminate the Al-Ko stabiliser on the caravan which works using friction pads clamped against the ball. I do put a small amount of grease on the mast ball and keep a second tow-ball cover on it whenever the mast is not in place. I periodically re-build the ball and the mast heel with chemical metal and super steel. Greasing reduces the necessary frequency of this.
