Comments on this site are not necessarily the opinion of the Dart 15 committee.
Comments are not moderated and people's screen names may not be accurate.
Do hull numbers relate in any way to the sail numbers?
Is there a record kept anywhere?
I ask this question not because I think it is a problem with Sprints, but it is with Lasers as people put newer numbered sails on old hulls & try to sell at inflated prices hoping the buyers will not know where to look for the hull number.
Halifax SWC God does not deduct from our allotted life span the time spent sailing(or talking, texting, reading, posting to websites & emailing about it)
My old Laser 60797 (yes that old), had the hull number under the front cleat. I think the new ones have it stamped in the cockpit some where. It was a basic check to match the hull number with the sail number. When I did the trade in for the Sprint 15 at the Laser Centre they knew where to find the ID !
After racing the 15 at Penmaenmawr in a nasty squally force 5 to 6 yesterday, my brother came ashore having struggled with a Laser radial and asked me how he could get hold of a Sprint 15. I won both races beating the 18's over the line in the second race.
Hi Charles, You are correct in that when the boats were made by Panthercraft every hull and issued sail number was recorded with a measurement certificate that could be tracked back to link hulls and sail numbers . Even if a boat had a replacement hull it was recorded at Panthercaft and the owner was oblided to up date the measurement certificated record. At events the mesurement certificate had to be presented at scrutineering and the the details had to tie up with the boat, it was a form of self policing. Things have moved on, laser were not quite so well organised on that front and records have been lost or not completed during that period . The question I guess is what age is a boat is it a hull ? both hulls? the sail numb er ? etc.
Since Windsport took over productrion and supply of new boats, we have moved back towards the original system. Windsport records the hull and sail number details of new boats and this keeps a record. Any boat that requires a new sail number, ie, has no recorded information to identify its true identity is issued with a number starting with a '0' . Originally all hull identification marked were resined into the hull and could be seen through the rear hatch S1, S2, now that we are part of the EEC every hull also has this information + the year it was built and by who on the outside near the transom.
We are in a period where some Sprint15's may be made up from one or more boats due to various reasons, may be it would be a good opportunity for the class to start recording and matching hull and sail numbers of the active fleet by inviting people to add their boat info on to a website directory (could be useful for potential theft purposes) or it could be part of the entry details at events.
Hope that bit of history helps.
Our rudders (15&18) also all have numbers etched into the blade at the top and the bottom casting of the masts originally had numbers - but have been changed now. I have recorded hull and rudder numbers of our boats in case of theft.
It might not be prudent to record details on the website, better by the association off line.
However I will make an offer to the 'committee' here. I would be quite happy to set up a spreadsheet or database for the association and record details for people - and maybe do association certificates of recorded details and owners. I have measurement certificates for my 18 and one of my Sparks but not the other one.
As Martin is the webmaster and we see each other virtually every week at SSC I am sure we could work something out for me to do the work and maintain an boat/owner/location database - maybe even with photos of hulls and sails.
If there are hulls without numbers perhaps some could be issued (association sequence) and marked inside hulls by owners so they can be recorded.
Brian - do you know if there is any paper record from Panthercraft or Laser ?
Steve Willis wrote:Our rudders (15&18) also all have numbers etched into the blade at the top and the bottom casting of the masts originally had numbers - but have been changed now. I have recorded hull and rudder numbers of our boats in case of theft.
Hi Steve,
Thanks for the offer. It would be good if you can do this for us. Clearly it would need Martin's help to get it on the website but as you are both at the same club it should help.
PS I don't think we should issue our own hull numbers as that would cause further confusion - we should just compile a data base of those that are known against the sail numbers. Everyone with a measurement certificate should know those of their boats.
PPS I have never found a hull without one. I guess if there has been a repair near the transom some may be lost.
