Plastic for trailer lighting boards
Post by WaveyDavey »
Not sure if anyone can help me here...
My current lighting board is an extra wide one, but still doesn't extend the full width of a 15. I'd prefer it to be wider so that I can more securely attach it to the transom brackets I have knocked up for each hull, and so the lights and safety triangles actually mark the extremities of the boat - especially for night towing.
Does anyone know where can I source a suitable length of the plastic cladding (or is it conduit?) that trailer lighting boards are made from? What is it called and what (if anything) is it sold for when not being made into lighting boards. I'd like to buy a length at least as wide as 15 (about 2.2m+ should do it). I'll cut it to size and remount all the bits from my existing board.
David
plastic products
Try using yell.com and searching on plastic products or UPVC suppliers.
The double glazers in most areas have some local plastics firm where they get window boards, cladding and trim etc.
I have been to our local one several times with various strange things needed - usually a quick tour of their stockrooms reveals something that will do - sounds like you want the sort of material that they use for 'headers' (add ons to raise the height of a upvc frame to fit an aperture or alternatively window sills (box section open lattice).
Most of their stuff comes in 3 or 5 metre lengths.
If you google 'Indespension', you can find a store in your area. They sell 7ft. lighting boards for around £45 which are wide enough for a Sprint 15. By drilling suitable sized holes in the underside, the board can be dropped straight on to the rudder pintles and tied on to the top rudder bracket on the transome. It will also come with more than enough cable to reach the car.
Otherwise, a bit of plastic fascia/barge boarding which would be used on domestic roofing, as Steve has suggested, would probably do the trick.
Cheers,
Thanks guys.
I'll try the "Mr Plastic" store in Chelmsford - sounds like the sort of thing they might do.
trailer lights
Post by Keith »
I remembered there was a long thread on this - It was posted 30th August 2007. As an observation, the plastic bit of the light fitting is remarkably similar to the white boards that are used for road works between bollards -if that helps.
Keith 1840[/img][/quote]
Thanks for this, Keith.
I have warned the police to be watchful for anyone in a wetsuit, lurking around roadworks.
